Adapting the mesh in Fluent
Old   January 13, 2014, 01:39
Default Adapting the mesh in Fluent
Sudipta Ray
Sudipta Ray is on a distinguished road
Hi everyone,
I am solving a problem of boundary-layer flow in fluent 13. To apply a particular turbulence model, I need to have a specific range of Y+ value at the wall. But the grid I'm creating in Gambit is not sufficient for it. Thus I'm trying to adapt the mesh via the y+ adaption scheme of Ansys Fluent itself. Is this particularly helpful? Fluent has created some hanging node mesh near the wall. I'm attaching the plot of wall y+ below. Please suggest if this technique is useful or not.
Sudipta Ray is offline   Reply With Quote
Old   January 18, 2014, 19:12
LDA
LDA is on a distinguished road
Yes it is useful. But the mesh element size will increase considerably if you have a poor mesh initially.
Try to use a higher quality mesh generator such as Pointwise. With their special technique it is far effective to modify a BL mesh compared to those in Gambit.
Good luck
LDA is offline   Reply With Quote
Old   January 18, 2014, 19:14
LDA
By the way, instead of checking y star check y+
Old   January 19, 2014, 02:19
Sudipta Ray
thanks LDA, i've meant to upload the y+ plot but somehow accidentally the y* one was uploaded. Also, about the initial mesh quality, I can say the mesh was structured with maximum aspect ratio 11.1 and minimum orthogonal quality 0.585. Is it not good enough, since I've read allowable orthogonal quality 0.5-1 and aspect ratio < 50. What can be said about this?
fluent 13, mesh adaption, turbulence model, wall y+
[ICEM] Using Surface Mesh from ANSA for Fluent Sim tommymoose ANSYS Meshing & Geometry 15 March 3, 2016 18:29
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[ICEM] Improving mesh orthogonality in ICEM or Fluent Harshal ANSYS Meshing & Geometry 0 December 2, 2013 10:04
Can anybody tell me what does fluent do using MESH MOTION? enry FLUENT 0 October 6, 2010 13:54
