Erinn Sapsford
Rep Power: 0 ![]() |
I am having some trouble setting up a scenario and was hoping someone could help. Basically the scenario is a pool of water with various obstructions within the pool, the pool has an inlet and outlet, and i am wanting to inject another chemical into the water and look at the movement of the chemical. I am not sure which models to be using, whether its a multi-phase or if i can use the energy model with K-epsilon and then turn on species transport. Another problem im getting is that if im using the inlet as the injection location for the water and chemical, how do i specify that two different materials are being injected from the inlet? Hope this makes sense, if not let me know and i will try to clarify. |
dispersion, fluent, mixing, species mixing |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
prePDF preprocessor in FLUENT (ANSYS 12 version) | anee | Fluent UDF and Scheme Programming | 7 | March 18, 2013 22:57 |
Fluent v6.3.26 better than Ansys v12.1 | jemyungcha | FLUENT | 2 | August 24, 2012 23:10 |
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation | Volker P. | ANSYS Meshing & Geometry | 22 | January 17, 2012 17:27 |
how to modeling heat by fluent and ansys? | njiit | FLUENT | 0 | December 9, 2009 00:39 |
