Rectangular Channel with 60 degree broken ribs. |
January 6, 2014, 11:55 |
iitd
Dear All
I am working on enhancement of heat transfer in a square channel through 60 degree V Broken in line ribs by using periodic, symmetric etc boundary condition. Ribs were placed on lower wall of the channel and symmetric condition were applied for the upper wall. Other two walls are adiabatic walls made of perspex. Ribs are adiabatic and made of perspex. flow field were assumed to be periodic and fully developed turbulent flow. constant mass flow rate were applied. I am facing problem in meshing and i have tried a concept to tilt the rectangular domain according to rib's orientation will it work. and if it works it will make my meshing easy and what parameter should I take care of because now domain is tilted with a angle (especially mass flow rate and velocity). If any one have any useful information regarding the problem please help. Regards Anuj shukla 09136271032 |
60 degree broken, fullydeveloped, periodic, ribs, turbulent |
laminar flow in 2d rectangular channel | arashmarahel180 | FLUENT | 4 | April 26, 2014 11:16 |
[GAMBIT] Boundary layer mesh & map mesh in rectangular ribbed channel | shayan_mv | ANSYS Meshing & Geometry | 20 | November 4, 2012 08:42 |
Gambit== how to draw a 180 degree curved rectangular in gambit | zaolon88 | FLUENT | 0 | March 25, 2012 01:17 |
Tollmien-Schlichting flow transition in 3D rectangular channel | QBeast | FLUENT | 0 | November 11, 2011 12:23 |
Velocity profiles for channel and rectangular duct | Jeff | Main CFD Forum | 0 | November 21, 2005 20:46 |
