Sebastian
Rep Power: 14 ![]() |
I've been reading a lot about DPM and particle surface reactions, but I can't figure out how does the reaction rate in Kg/s is used to report a reaction rate in Kgmol/m^3 s in the contours. I mean, in the UDF (DEFINE_PR_RATE) I impose a reaction rate of 1e-5 Kg/s, and then I'm sure fluent does something else with that reaction rate and the particles mass don't decrease 1e-5 Kg/s, and as I have different reactions, if I input the same rate, as example 1e-5 Kg/s, some rates are reported different in the contours. If someone understands how this works, please explain me. Thank you so much for your answer.
define_pr_rate, dpm, fluent - udf, particle surface reaction, reactions |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
Particle Surface Reaction | NunoLFC | FLUENT | 0 | June 22, 2011 10:52 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
Both volumetric and surface reactions | Leverkin | FLUENT | 2 | July 15, 2009 17:07 |
