Divergence using pressure-based method in dynamic mesh case |
December 31, 2013, 23:05 |
Jiweiqi
Rep Power: 14 |
I am using dynamic mesh. But if i apply a pressure-based solver to it right now after initializing, it diverged. If i applied a coupled method and apply a pressure-based method, it converged again. Is it OK to using Coupled at the beginning and pressure-based solver late. |
January 1, 2014, 07:34 |
I think the dynamic meshing module is not dependent on the flow solver. The coupled solver converges quickly than the normal pressure simplec scheme in terms of iteration number, but it takes more computational resources for each iteration. Eventually you should get similar results with both the approaches. |
January 1, 2014, 12:48 |
#3 | |
Jiweiqi
Rep Power: 14 |
dynamic mesh, solvers |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
simpleFoam kOmegaSST LowRe pressure divergence | Pat84 | OpenFOAM Running, Solving & CFD | 2 | August 12, 2013 18:42 |
Dynamic Mesh in an In-cylinder case | venkitaraman | FLUENT | 0 | March 26, 2007 18:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
