Mesh importing
Old   December 20, 2013, 06:11
Question Mesh importing
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
I generated the mesh by ICEM. I'd like to import one mesh from one .msh file then import another mesh from another .msh file to fluent. Then create GGI interface between the two mesh for connection. This can be simply done in CFX. But when I come to Fluent, the previous mesh is always replaced when I import the second mesh. May I ask how to import mesh without deleting the mesh already exist in Fluent?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   December 20, 2013, 06:58
Zaktatir is on a distinguished road
in less than 30 seconds found:
6.3.15 Reading Multiple Mesh/Case/Data Files
Zaktatir is offline   Reply With Quote
Old   December 20, 2013, 07:05
Question
Anna Tian's Avatar
Meimei Wang
I tried with tmerge -2d -cl -p my1.msh my2.msh final.msh
But it shows 'invalid command [tmerge]'.
How to solve this problem?
Best regards,
Meimei
Old   December 20, 2013, 07:18
you have to specify the path the command since i assume that is not set as environment variable.
Use the other way since you do not need any external handling.
Old   December 20, 2013, 07:44
Anna Tian's Avatar
Meimei Wang
It's solved. Thank you very much!
Best regards,
Meimei
Old   December 22, 2013, 16:09
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
you can do it easily with append option...
Far is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
