filling closed vessel with compressible gas
Old   December 20, 2013, 05:24
Default filling closed vessel with compressible gas
NAD
NAD is on a distinguished road
I posted this problem before but I didn't get any suggestion. I decided to post it again with a simple scheme maybe someone could help me.
I want to simulate the problem described in the figure by using multiphase model.
I don't know how to set up the problem, particularly the BC.
have you any idea about that?
Thanks in advance.
NAD
NAD is offline   Reply With Quote
Old   December 20, 2013, 05:27
NAD
sorry
the figure is within this post
Old   December 20, 2013, 05:46
Zaktatir is on a distinguished road
Do you not have any outlet in you problem? And Why multiphase if you are only using air
Zaktatir is offline   Reply With Quote
Old   December 20, 2013, 06:00
NAD
HI Zaktatir,
yes, without outlet.
Multiphase, because later I want to use solid particles instead air .
the simulation is very short in time, I mean the physical time is less than 0.2 millisecond.
Old   December 20, 2013, 06:47
You said instead of air! That means in your final simulation how many fluids or media are present in your domain.
Do you know the velocity of the entrance area or that will be atmospheric conditions at the entrance level?
Old   December 20, 2013, 07:26
NAD
In the final simulation the vessel is filled with solid (with a known porosity).
at the inlet, I know that the compressible gas at temperature of 2500k, and pressure of 7.4 MPa, enters into the domain with velocity equals to 45 m/s.
Old   December 20, 2013, 07:30
I think first of all you need to concentrate your self on getting stable setup for your air simulation: that will be though since there's no physical outlet in your domain. By the way do you expect reversal flow at the inlet? I think that it will come to that anyway.
That's suggestion a pressure inlet at the inlet or modified pressure outlet with the inlet specification as backflow input
Old   December 20, 2013, 07:43
NAD
Yes, first I will do the "with air" simulation.
for the inlet, I have two choicesressure inlet or mass flow inlet.
if I choose the pressure inlet I would have reversal flow at the inlet. but I don't know how set up the inlet pressure .
sorry, but what do you mean be"modified pressure outlet with the inlet specification as backflow input"?
Old   May 4, 2017, 01:21
Bharatvaaj
Vaaj is on a distinguished road
Hey guys,
I am also trying to simulate filling of air into chamber with some air. Did you get answers for your simulation. I have a varying inlet mass and pressure. How do I initialize?
Vaaj is offline   Reply With Quote
closed vessel, compressible, multiphase flow
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Gas filling in closed vessel chanfire CFX 3 February 16, 2010 18:23
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
