Convergence
Old   December 19, 2013, 01:50
Default Convergence
EMAVI V SURYA SAMPATH
sampathevs is on a distinguished road
Hi all,
(In FLUENT 14.5)
My solution is converged and all the flow rates etc got balanced. Even my plots are according to my expectations. But, the residuals got settled at e-02.
Any tips or tricks to make lower these residuals , at-least till e-04.
1. Tried by changing URF's. Need any other suggestions.
2. Done standard initialization ( Tried with hybrid as well, but obtained same result)
3. Trying for first order convergence
Will be glad if anyone can reply .
Thanks and Regards,
Sampath Emani
sampathevs is offline   Reply With Quote
Old   December 19, 2013, 12:00
Yogesh Patil
foamcfd is on a distinguished road
If you are satisfied with the results then you shouldn't worry about the residual values. Residual is one of convergence criteria and not the convergence criteria. You can also monitor variables at various location to make sure that solution is converged.
If you have natural convection in your problem then you are more likely to get residual which you are getting. Try flipping URF for pressure and momentum if you are using seggregated solver.
foamcfd is offline   Reply With Quote
Old   December 20, 2013, 01:06
Thanks for the reply.
I gave outflow boundary condition to the outlet. Hence, the residuals got stuck at e-02. When i tried by changing it to pressure outlet, residuals got reduced till 4.
this is for species transport simulation.
Regards,
Sampath emani.
convergence criteria, fluent
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 15:20
Convergence problems Chetan FLUENT 3 April 15, 2004 20:13
