December 17, 2013, 14:49 |
Change from serial to parallel
Meimei Wang
Rep Power: 16 |
I choose 'serial' as my processing option when I first launch Fluent. Then later on, as I replaced the mesh, I'd like to change to 'parallel'. I'm wondering what is the easiest way to change to that. I didn't find the launch window any more after I come to the Fluent operation interface.
Best regards, Meimei Last edited by Anna Tian; December 18, 2013 at 04:58. |
December 17, 2013, 16:30 |
Rep Power: 17 |
??? i dunno understand
December 17, 2013, 18:16 |
Alex
Rep Power: 49 |
I guess you are using ansys workbench.
When clicking only once on the fluent module, you should see the option to "show fluent launcher at startup" or something similar. Check this tickbox. Somewhere in the same region, you could also directly specify to launch fluent in parallel without the laucher showing up every time you open it. |
December 18, 2013, 01:35 |
vidyanand
Rep Power: 17 |
click on set up in workbench, in properties activate the run-parallel check box and state the state the number processor
if you can't find properties menu then it file -properties |
Poisson eq w setReference works serial diverges in parallel | tehache | OpenFOAM Running, Solving & CFD | 5 | August 29, 2012 10:41 |
UDF Parallel error (Is operating only in the serial.) | startup0820 | Fluent UDF and Scheme Programming | 0 | March 7, 2012 08:26 |
Help: Serial code to parallel but even slower | Zonexo | Main CFD Forum | 4 | May 14, 2008 11:26 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 13:00 |
