Problem with modelling heat exchanger(fluid-solid-fluid-solid)
Like Tree4Likes
Old   December 16, 2013, 09:21
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Ok, where is the line located (regarding x-direction)? In the middle of your pipe?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   December 16, 2013, 09:30
saman poura
samanpoura is on a distinguished road
line start from the cennteral point of iner pipe and end on outer surface of outer pipe
samanpoura is offline   Reply With Quote
Old   December 16, 2013, 09:37
Philipp
Yes, but regarding x-direction?
Also, if you don't have periodic b.c. in x-direction: Where did you make the contour plot and what b.c. did you set for the inner (solid) pipe at the pipe's ends?
Old   December 16, 2013, 09:41
saman poura
can u give me a email and i send u cas and data?
i cant find the problem ):
Old   December 16, 2013, 10:50
Philipp
Look at your velocity profile. This looks like a rectangular function. This can't work.
Your problem is, that
1) Your fluid mesh is much too coarse. You only have 10 gridpoints for a pipe flow that probably is turbulent.
2) You don't use a turbulence model.
-> Make the mesh much finer and use a turbulence model.
samanpoura likes this.
Old   December 16, 2013, 17:36
saman poura
thank u very much
fluid-solid-fluid-solid, heat exchanger model, two-sided wall, wall thickness
Modeling heat transfer fluid to solid Elvis1991 FLUENT 6 December 7, 2012 10:08
Heat Flux at Internal walls or Fluid Solid Interface Mahi CFX 3 October 1, 2012 03:18
goddamnit: how to set up heat transfer from fluid to solid macfly FLUENT 7 June 16, 2012 12:50
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 21:11
Conjugate Heat Transfer between fluid and solid Li Yang Main CFD Forum 8 March 27, 2004 12:05
