Applying hydrostatic pressure at Pressure inlet |
December 11, 2013, 17:29 |
Tanjina Afrin
Rep Power: 13 |
Dear All,
Could anyone please suggest me how can I apply hydrostatic pressure at a vertical pressure inlet? Or is it possible in fluent or not ? Any help will be really appreciated. Regards, Tanjina |
December 14, 2013, 18:26 |
Rep Power: 17 |
Yes turning the gravity on give a reference density and work on defining the hydrstotic pressure which is then problem dependent. In your vertical tube that will b easy through patching the domain with the hydrostatic pressure.
December 14, 2013, 21:12 |
#3 | |
Tanjina Afrin
Rep Power: 13 |
Thanks a lot. Could you explain a little bit more? Please find the image of my model on Ansys Fluent. Left side is the inlet and BC for that side is hydrostatic pressure. So I tried to use Pressure inlet. But for pressure inlet, I can input total gauge pressure, not the hydrostatic pressure. So I was seeking any type of help or suggestion from anyone. Thanks again. Regards, Tanjina |
hydrostatic pressure, pressure inlet |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 11:08 |
How to set up the inlet boundary condition for a low pressure case? | beastieboys6 | FLUENT | 3 | April 10, 2012 23:46 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 12:08 |
Setting dynamic pressure as the inlet BC | ruined | FLUENT | 1 | March 26, 2008 06:30 |
Pressure inlet definitions | Christian | FLUENT | 0 | April 15, 2003 08:24 |
