Dynamic Mesh resulting in Curved Grid Lines
Old   December 5, 2013, 11:25
Default Dynamic Mesh resulting in Curved Grid Lines
adubois is on a distinguished road
I am modelling a heaving and pitching foil using an inner grid around the foil which moves using a define_zone_motion udf (grid within zone does not deform) and an outer grid which deforms according to the motion of the inner grid (defined using a define_cg_motion udf). The second and third image show results of the motion on a very coarse grid (motion shows the wanted behavior).
The problems start when I use a proper grid (meaning a refined grid, using much more node). The outer grid does not deform as wanted and will results in negative cell volumes. This problem is in my opinion caused by the fact that the lines in the outer grid do not deform a straight lines as wanted but get a curve in them (as can be seen in the first image). Anyone suggestions in how to resolve this issue?
Thanks in advance
PS If you would want more information or a video of the motion (to better understand the problem), leave your email adres and i will try to respond as good as possible
adubois is offline   Reply With Quote
Old   April 17, 2014, 02:30
navid
ndabir is on a distinguished road
I have a similar problem? did you find what is the solution to it?
ndabir is offline   Reply With Quote
Old   April 17, 2014, 04:42
I did not find a solution, I used a unstructured grid in the outer region and allowed for remeshing and solved it that way.
Old   April 17, 2014, 11:06
stumpy is on a distinguished road
Do you have rotations for the inner mesh region, or just translations? If you have rotations the I would use a non-conformal interface between the two regions and allow sliding, so the rotational components don't get passed to the outer mesh.
stumpy is offline   Reply With Quote
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 09:27
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 23:09
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 06:02
Some questions about mesh updating in dynamic mesh technique lzgwhy Main CFD Forum 0 June 14, 2009 09:01
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
