Density problem in fluent
Old   December 10, 2013, 15:57
Zaktatir is on a distinguished road
Node values are explicitly defined or obtained by weighted averaging of the cell data. Various boundary conditions impose values of field variables at the domain boundaries, so grid node values on these boundary zones are obtained by simple averaging of the adjacent boundary face data. In addition, for several variables (e.g., node coordinates) explicit node values are available at all nodes.
By the way we do not have any entrainment of air or tearing off of liquid. It would be better if you would like to sharpen the interphase to geo-reconstruct. The free surface is still at 0,5.
Zaktatir is offline   Reply With Quote
Old   December 10, 2013, 16:09
ghost82's Avatar
Rick
ghost82 will become famous soon enough
You should see more definite water and air phases. Can you post here the 2 contour plots with and without node values?
ghost82 is offline   Reply With Quote
Old   December 11, 2013, 09:22
FHydro
flow_CH is on a distinguished road
Please see attached image
flow_CH is offline   Reply With Quote
Old   December 14, 2013, 08:41
FHydro
Let me say this problem another way.
My flow depth in experiments is 1.5 meters. I have flow depth=1.5 meters in fluent too (from volume fraction 1 to 0.5). Then OK.
But from volume fraction 0.5 to 0, the distance is about 1 meter!
I mean the difference between VF=0.5 to VF=0 is very large. (about 1 meter)
What is reason of this problem?
Thanks
Old   December 14, 2013, 08:57
Do you mean with your flow Depth the film thickness?
Old   December 14, 2013, 09:14
FHydro
I am sorry i don't understand. If i decrease the size of mesh, then the distance between VF=0.5 and VF=0 decrease too?
Old   December 14, 2013, 10:20
FHydro
Old   December 14, 2013, 11:03
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
From the contour without interpolated "node values" we can see that the cell size is quite large and definitely affects the width of the interface between the two phases.
Decreasing the cell size should also decrease the distance between VF=0.5 and VF=0
flotus1 is offline   Reply With Quote
Old   December 14, 2013, 11:23
FHydro
Thank you flutus1
I have very large issue. I modeled this simulation for 5 times. I have just 2 month for my thesis and i can not decrease mesh. For sketching air concentration (void fraction), can i equivalent VF=0 with VF=0.5 since this modeling is true and problem is just from meshing?
Old   December 14, 2013, 11:48
Try to make a dynamic adaption starting from this solution and use compressive scheme (which is more quicker and more stable than geo-recon). The adaption should occur by means of the gradient of VOF.
Or you can refine your mesh only in the vicinity of the free surface since you now approximately when it sets in. Interpolate the old results in the new one.
I do not like to comment your intention to assume VOF= 0,5 to be zero...
Old   December 14, 2013, 16:02
FHydro
Thanks.
1- What is dynamic adaption?
2- With increasing mesh by refining, The time for iterating will be too long. In the present (without refining), the time for iterating of my model is about 26 hours (number of elements is: 1 600 000 elements). Then if i refine the mesh and with 5 simulation, i think i need 2 weeks for iterating (just for a mesh).
3-Why you do not like to comment about assuming VF=0 to VF=0.5? Because i thing my problem is just about meshing and there is no other issue.
Old   December 14, 2013, 18:32
flotus1's Avatar
Alex
Is there more to this simulation than you have shown by now? To me it looks like quite a simple flow and I dont see where you put those 1.6 million cells.
Old   December 15, 2013, 01:24
FHydro
Model is 3d and the length is 270 meters in prototype.
Old   December 15, 2013, 07:49
flotus1's Avatar
Alex
I think he doesnt want to comment on this because the assumption is, lets say daring.
You would not define velocity=1 \equiv velocity=0.5 just to get a different thickness of the boundary layer that better suits your expectations.
Since there were a lot of comments that were not particularly helpful, I suggest you re-express the problem you are facing in detail.
Then I suggest the experts here have another look on the topic and try to comment from a more professional perspective
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 17:33
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 15:20
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 14:31
Problem about Fluent on Linux hbinma FLUENT 3 July 6, 2008 11:49
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 05:13
