Contour of temperature shows abnormal temperature from expected
Old   December 2, 2013, 22:49
Default Contour of temperature shows abnormal temperature from expected
cwc
WC CHONG
cwc is on a distinguished road
Hi. I am a new user in ansys fluent.
I've done couple of study on the a laminar flow of air in a pipe with dimension 0.06m height and 5.76m width. I applied 1000 W/m2 heat flux at the top section of the fluid wall. but the temperature contour shows that the heat flux caused the the temperature of exit is 1990 Kelvin. May i know any changes i can make to fix this issue? Thanks and best regards
cwc is offline   Reply With Quote
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
wmake compiling Problem with OF1.5 openTom OpenFOAM Installation 4 May 3, 2009 15:44
Compiling OpenFOAM13 on AMD64 with OpenSUSE 101 silent_missile OpenFOAM Installation 5 August 10, 2007 08:31
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
