December 2, 2013, 02:30 |
simulation with inlet and no outlet
Rep Power: 14 |
I want to use multiphase flow to simulate this case: An empty closed chamber with one inlet and without outlet. At t=0s, an under-expanded jet of hot gases and particle enter to the chamber through the inlet. The mixture of gas-particle entering to the chamber has a high temperature (2500K) and a pressure (8MPa). the simulation is 2D. Any one has an idea how to do it? particularly, how to set BC? Thanks in advance. |
closed space, compressible flow, multiphase flow |
