November 18, 2013, 17:07 |
Pressure gradient through vertical pipe
Aileen Magee
Rep Power: 13 |
Hello there,
I am trying to simulate flow of a fluid through a vertical pipe. The fluid properties depend on pressure. The inlet of the pipe is a velocity inlet with a pressure of 0Pa. The outlet is a pressure outlet at 80Pa. I am wondering why I do not get a linear pressure gradient along the pipe as pressure should increase gradually as you travel down the pipe. Instead on plotting pressure contours I get results that the whole pipe is at 0Pa apart from the very outlet boundary. Could anybody explain why this is? Thankyou |
vortex cause pressure gradient or pressure gradient induce vortex? | fruitkiwi | Main CFD Forum | 4 | June 12, 2012 01:12 |
how to get pressure and pressure gradient using UDF | Honglin | Fluent UDF and Scheme Programming | 0 | May 24, 2012 06:47 |
How to find the reflections of the pressure wave in pipe lines | RKR | Main CFD Forum | 0 | April 6, 2011 08:08 |
How do i measure pressure gradient along a pipe? | mayur_ | Main CFD Forum | 1 | July 31, 2010 07:12 |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 06:52 |
