Natural convection from heatsink
Old   November 18, 2013, 10:12
Default Natural convection from heatsink
freefall is on a distinguished road
I'm currently simulation natural convection in 3-D from a plate-finned heatsink with multiple heatgenerators.
I use pressure-based solver, with gravity.
  • Energy equation
  • k-epsilon turbulence, with scalable wall fc and full bouancy effects.
  • P1, with emissivity:0,85 on most solids.
i use Simplec with discretizations:
  • standard pressure
  • Second order on the others
as materials there is only air and aluminium
Questions regarding air properties:
  1. How do i best define density for air here? I have used mostly boussinesq approx. Here i wonder what sould i define operating temerature as? (in operating conditions) Should it be my ambient air temperature, or should it be the same temperature as the boussinesq density is defined (in materials) I have also tried incompressible ideal gas with a defined density (in operating conditions) With this it seems to get alot hotter, about 10 degrees...
  2. An is it possible/meaningful to use piecewise polynomial to define thermal conductivity, Cp and viscosity and still get convergence? Or should i define them as constants?
freefall is offline   Reply With Quote
Old   November 18, 2013, 10:14
forgot to mention that my deltaT is around 40 degrees at the most, So Ra=laminar.
Thermophysical properties for natural convection Ciefdi OpenFOAM Running, Solving & CFD 0 November 7, 2013 12:44
Flow around cube and cube natural convection Mirage12 OpenFOAM Running, Solving & CFD 5 June 15, 2013 12:20
natural convection problem with radiation jorien CFX 0 October 14, 2011 10:26
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 05:58
natural convection at high Rayleigh mauricio FLUENT 2 February 23, 2005 20:43
