is it necessary to multiply by number of blades with moment to calculate the power? |
November 16, 2013, 06:48 |
ijaz fazil
Rep Power: 13 |
Hi
I have done the simulation of wind turbine using MRF analyis. I have not done any symmetric analysis. I have done whole blade simluation. But when I calculated power, it is half the value. My friends suggested that I should multiply by number of blades to calculate the power from moment value? Is it so? |
November 16, 2013, 09:35 |
Rick
Rep Power: 27 |
if you simulated the whole 3d model you have not to multiply by the number of blades; you have to multiply only if you do periodic simulations. Daniele |
November 16, 2013, 20:04 |
Hi, then do u have an idea where i'm going wrong
ijaz fazil
Rep Power: 13 |
Hi
I run two simulations one fo 7 m/s and another for 10 m/s. In both cases my power is half of the experimental. I think I have a problem with direction of rotation. I have a doubt while using thumb rule, index finger should be pointed from inlet to the blade or the index figer should point from blade to inlet |
power, torque, windturbine |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
calculate pitching moment coefficient | jyh3134 | FLUENT | 0 | January 30, 2013 11:40 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 23:40 |
How to calculate inlet swirl number in Post? | CFXPostuser | CFX | 8 | April 29, 2009 14:50 |
Calculating pitching moment for power input | Zonexo | Main CFD Forum | 0 | June 12, 2008 07:07 |
