Porous Media
Old   November 11, 2013, 12:45
Default Porous Media
Disabled
anon_m is on a distinguished road
I am trying to model the flow from a tube towards a porous media. I define two parts in geometry, and create a named selection in mesh section for the interface between the bodies. In Fluent I also define a mesh interface. I set up the variables and what I get as a result is that the flow doesn't go much further after the interface as it acts as a huge block in the flow. I am not sure what I am doing wrong.
I appreciate your help.
anon_m is offline   Reply With Quote
Old   November 13, 2013, 01:38
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you don't need to define interfaces.
Interfaces in the sense of Fluent are usefull for glueing 2 meshes which are not connected. (and not an interface between 2 phases)
So you need to reconnect both domain, and you also need to assign 2 different continuum (1 fluid and 1 porous)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 13, 2013, 08:24
Disabled
Thanks.
But how can I reconnect the domains? I am developing the model is ANSYS model designer, and defining two body parts there. I think I need to have 2 lines for the boundary b/w fluid and porous to make separate parts. When I go to Fluent these lines are set to wall B.C.
Old   November 13, 2013, 08:29
-mAx-'s Avatar
Maxime Perelli
I have 0-experience with Ansys. I only explained what you should do in Gambit for Fluent
Old   November 13, 2013, 08:34
Disabled
probably there should be a similar way to do what you said, I'll try to reconnect the zones then.
I appreciate your help )
porous media
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
species mass source in porous media ? PK FLUENT 0 February 16, 2007 12:12
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
