Assign static pressure at inlet
Old   November 3, 2013, 12:34
Default Assign static pressure at inlet
Tanjina Afrin
Tanjina is on a distinguished road
Hello all,
Is there any way so that I can assign static pressure zero at inlet? Mt BC for inlet is pressure inlet since I don't know the velocity and flow rate at inlet. At inlet I can input "total Gauge pressure " which is combination of static+dynamic pressure. But I have to assign static pressure zero as BC. Is it possible ?
I have another problem. If I create an line say "line 22222" in inlet ( 2D case) and see the static pressure from fluent, I found it different from the static pressure at "inlet" ( which I named inlet before meshing). Anyone has any idea why they are so different ?
Thanks in advance to all.
Regards,
Tanjina
Tanjina is offline   Reply With Quote
help with boundary profile in pressure inlet quiqui FLUENT 21 June 18, 2013 13:55
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
How to achieve constant static pressure in inlet? Zou Jianfeng FLUENT 0 October 21, 2008 02:55
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 15:57
Pressure Inlet yields wrong velocities Ben FLUENT 0 November 21, 2004 02:47
