Fluent warning Hexahedral or polyhedral cell problems
Old   November 3, 2013, 10:44
Default Fluent warning Hexahedral or polyhedral cell problems
le hoang anh
lehoanganh07 is on a distinguished road
Hi everyone,
I try to make structure mesh for my model (nozzle). I make quadrangle cell for nozzle hole and mapped face meshing for my model like picture below. But when I ran and check the mesh in Fluent, it warning that:
WARNING: The mesh contains high aspect ratio hexahedral
or polyhedral cells.
The default algorithm used to compute the wall
distance required by the turbulence models might
produce wrong results in these cells.
Please inspect the wall distance by displaying the
contours of the 'Cell Wall Distance' at the
boundaries. If you observe any irregularities we
recommend the use of an alternative algorithm to
correct the wall distance.
Please select /solve/initialize/repair-wall-distance
using the text user interface to switch to the
alternative algorithm.
Could you help me to fix this problem, I did not find /solve/initialize/repair-wall-distance they said to repaired the mesh. Furthermore, could you suggest me how to make quadrangle for the region in red circle!
lehoanganh07 is offline   Reply With Quote
Old   November 6, 2013, 02:49
vidyanand
Vidyanand Kesti is on a distinguished road
DID GET GET ANY WARNING IN QUALITY CHECK?
If you get wraning in qulaity check then you have highly skewed cells in the doiman ,so those cell you can convert to ploy
Vidyanand Kesti is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[swak4Foam] wmake groovyBC in OpenFOAM 1.7 ? randomid OpenFOAM Community Contributions 1 August 27, 2010 06:15
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit coompressor OpenFOAM Installation 0 November 12, 2008 20:53
OpenFoam 14 installation problem gfcoppola OpenFOAM Installation 20 November 2, 2007 14:38
