#21 | |
Rep Power: 9 ![]() |
Do you have email, I can send you a file. |
#22 |
Is there any particular reason for using Explicit VOF? If you are modeling a falling film and the film is quite thin, better to use Eulerian Wall Film model. Modeling a thin film with VOF is always expensive. Other option is to use Implicit VOF along with LSM to improve accuracy.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
#23 | |
(2)I do not know how I can use a Eulerian Wall film model, can you tell me how I can set it? Or I can send my case to you. If you are available, I can send you by email. For the forum can not submit a file exceed 195.3 Kb. (3)What is the LSM, how can choose the Implicit VOF along with LSM. Thank you very much for your reply. |
#24 |
Geo-Reconstruct is the best reconstruction algorithm available in Fluent, however, CICSAM is good as well and is available with implicit VOF.
EWF is a separate model under Models. But it is not available under older versions. I suppose this is available starting from R14. LSM is level set method. It is not available as a stand-alone model in Fluent but in combination with VOF. This is useful for scenarios that have significant surface tension.
#25 | |
#26 |
Transient formulation in Fluent's pressure based solver is always implicit. Implicit means that VOF capturing is implicit.
#27 |
But we I choose the implicit VOF capturing, there is no CSCSAM option for the volume fraction, there are only "compressive" and "modified HRIC" optiions. Only I use explicit VOF capturing can I choose the CSCSAM option.
#28 |
In place of CICSAM, use compressive.
#29 |
#30 |
As stated earlier, Geo-reconstruct is the best available option. However, this is about reconstruction of the interface. Capturing depends a lot on the mesh. If the mesh is fine enough, results will be acceptable. If the film thickness is less than 1 mm, I'd recommend using EWF instead of VOF.
#31 | |
#32 |
#33 | |
#34 |
VOF is applicable as long as N-S is applicable, however, it becomes very expensive since a very fine mesh, spatial as well as temporal, is required. EWF can be used as long as film thickness is lesser than first cell height. So, you would need a coarser mesh. 1 mm is just a recommended value, you can use EWF for thicker films as well.
#35 | |
#36 |
For normal flows, mesh size is usually selected on the basis of
#37 |
Do you know why the mesh is not uniform(see the attachment) around the tube surface?
#38 |
The mesh is already as uniform as it can get. It's the height of first cell and the growth rate that matters.
#39 |
You mean it is reasonable for this phenomenon, I can not understand, but I find that the mesh in the article have not the phenomenon, why?
#40 | |
Collection efficiency calculation and running wet and runback analysis on wing Copy the files, (NACA_0012.msh, film_accretion.c) to the working folder. Thank you for sending me[/QUOTE] |
Courant number | fireman | FLUENT | 7 | September 11, 2021 11:33 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
LES near wall model & courant number | kasim | CFX | 5 | March 16, 2008 18:23 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
