October 31, 2013, 16:15 |
problem in pressure result using periodic BC
Adib
Rep Power: 13 |
Hi
I am modelling a 2D pipe using periodic BC but as you see in the picture contours of "static pressure" show non-logical result. the description of what i did: scale cm - making periodic by TUI - laminar - material water - mass flow rate 0.05 - SIMPLE - interval size of mesh 0.01 - dimension 4*1 cm NOTE! if I do the same work with a geometry that has barrier in the path of flow (like example of fluent tutorial for periodic BC) I get normal result and this problem occur just in simple geometry. |
November 9, 2013, 13:07 |
Adib
Rep Power: 13 |
Hi
I still have problem. could someone help me? |
March 4, 2015, 15:44 |
daniel
Rep Power: 12 |
Did you ever figure out a solution?
I have a similar problem but in a 3D pipe flow |
Pressure Boundary Condition Problem | rbjet | CFX | 3 | July 15, 2013 22:45 |
Operating Pressure (Natural Convection problem) | Andrew Tress | Main CFD Forum | 1 | July 3, 2006 17:00 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
a problem in calculating pressure drop in Fluent? | yu chun | FLUENT | 1 | May 18, 2004 04:40 |
Periodic flow boundary condition problem | sudha | FLUENT | 3 | April 28, 2004 09:40 |
