Fluent 14 processor and memory setting
Old   October 29, 2013, 23:16
Default Fluent 14 processor and memory setting
mosyarus
mosyarus is on a distinguished road
HI, I use AMD FX-8120 8 processors and 8gb RAM. When I start Fluent 14 I use parallel processing with 8 processors. When I run Fluent I notice that all my 8 processors running on 100% load and my memory only 20+% used. Is it normal or I can change another setting for better performance.
mosyarus is offline   Reply With Quote
Old   October 31, 2013, 10:33
Claudio
cdgatti is on a distinguished road
I have the same computer. The RAM memory usage depends on the complexity of the model that are running, the more complex, more calculations must be done and more RAM to use.
cdgatti is offline   Reply With Quote
Old   October 31, 2013, 22:11
mosyarus
tq Claudio for the reply,can i have other setting to reduce the calculation time with the same model?
Old   November 1, 2013, 06:50
Claudio
Making an initial initialization potential flow by FMG, you greatly reduce convergence time (if you're not doing). Another way is to improve the quality of the mesh (skew <0.9). Otherwise reducing relaxation coefficients, and the number Courant.
I hope to be of your help
Old   November 5, 2013, 23:36
mosyarus
Thank you for the suggestions. I hope your suggestions can help me for my simulations. Thanks again
amd, memory, processor, setting
