How to run a long simulation?
Old   October 27, 2013, 11:05
Default How to run a long simulation?
Aileen Magee
0906536m is on a distinguished road
I am new to Fluent, but I would like to run a simulation for 300, 500 and 1000 years and have no idea how to go about this as when I try to run this as transient the maximum time step it will allow is 1 second. Any suggestions would be more than appreciated!
Kind Regards!
0906536m is offline   Reply With Quote
Old   October 28, 2013, 14:36
delaneyluke is on a distinguished road
What is it that you want to analyze or what is the problem you want to study?
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   October 28, 2013, 18:29
Aileen Magee
Hello, I am wanting to model CO2 migration from a saline aquifer.
Old   October 29, 2013, 00:26
RossFS is on a distinguished road
It would be worth your while to look into using the adaptive time stepping method which can alter the size of the time step depending on whether you are getting significant gradients in the variables of interest (or something like this). This would reduce the time required to generate your solution as when things are happening slowly the time step would be large and when things are happening rapidly the time step would be reduced.
FYI: I can set a fixed time step to 100,000 seconds in Fluent in ANSYS version 14. I could probably set it higher if I wanted to.
RossFS is offline   Reply With Quote
Old   October 30, 2013, 01:10
quantities is on a distinguished road
In aerodynamics experiment, sometimes the wind tunnel is too small to place the real airplane, so people make a miniature model and keep the Reynolds and Mach number same as the real case, the flow around miniature model will have similarity as the real case. You can try the same method: shorten the flow time but keep the key dimensionless parameters unchanged.
quantities is offline   Reply With Quote
How to run a wind turbine blade simulation gerritgroot SU2 6 February 8, 2019 15:44
Flow 3D Cast_can not run simulation pcapsa FLOW-3D 2 June 21, 2013 05:21
Long time CHT transient simulation time step.... JP CFX 0 May 9, 2008 04:36
simulation of the long and short wave radiation slim FLUENT 0 December 1, 2007 16:01
Procedure to run unsteady simulation? STN Main CFD Forum 2 February 16, 2002 05:37
