non-uniform inlet velocity simulation in Fluent 13.0
Old   October 24, 2013, 22:04
Default non-uniform inlet velocity simulation in Fluent 13.0
shuminhua
shuminhua is on a distinguished road
The performance of propeller is computing in Fluent 13.0. The inlet velocity which is non-uniform inflow was given using UDF in fluent. When I use turbulence model to simulate, the inlet velocity dissipated quickly (The plane close to the inlet whose velocity like the uniform). When I use Laminar or Inviscid model to simulate, there is no dissipation (the outlet velocity is similar to the inlet velocity)
Can someone give me a hint on how to do that ?
Thanks for your help !
shuminhua is offline   Reply With Quote
Old   October 25, 2013, 03:36
Astio Lamar
asal is on a distinguished road
"The inlet velocity which is non-uniform inflow was given using UDF in fluent."
for this you should compile a UDF to impose a velocity profile through the inlet. or you need to use points!
For UDF you need to fit a polyline to the inlet profile velocity and then impose this polyline.
here is an example of the velocity profile UDF:
#include "udf.h"
DEFINE_PROFILE(inlet_velocity, thread, position)
real z[ND_ND]; /* this will hold the position vector */
real y;
face_t f;
begin_f_loop(f, thread)
F_CENTROID(z,f,thread);
y = z[1];
F_PROFILE(f, thread, position) = 0.3-0.4*y+0.6*y*y;
end_f_loop(f, thread)
the red equation is the mentioned polyline.
asal is offline   Reply With Quote
Old   October 27, 2013, 20:17
shuminhua
Thanks and sorry for my poor English.
In my case, I give the UDF in fluent and the inlet velocity shows from the velocity contours which seems to be no problem.
I use Inviscid and Laminar model (Viscous model) to simulate,the velocity of the sections parallel to the inlet are similar to the inlet velocity(the inlet velocity are non-uniform). But when i change viscous model to two equation turbulence model (SST , RNG),the velocity of the sections parallel to the inlet which are fully uniform(the dissipation are very quick).
thanks
second order schemes marine OpenFOAM 67 April 11, 2022 19:19
Using a variable (increasing) inlet to get an easy convergence/initialization ? fredo490 OpenFOAM Running, Solving & CFD 8 April 9, 2014 10:35
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 15:16
fluent inlet velocity setup linyx FLUENT 5 February 23, 2012 12:36
Channel flow: Inlet pressure AND uniform velocity? frmap1 Main CFD Forum 0 April 15, 2010 11:32
