October 22, 2013, 16:36 |
Solution diverge with small element size.
salvatore
Rep Power: 16 |
Hi All
I am using FLUENT to study the flow in an aorta. Specifically, I am performing a mesh quality analysis to assess the best element size and the optimal value of wall shear stress. The problem is that the solution diverge with small element size. Specifically, a mesh with 700000 element (skewness is about 0.75) shows convergence while meshes with 1400000 (skewness is about 0.84) elements or 2100000 elements (skewness is about 0.86) show divergence. Meshes with high number of elements diverge using either Simple or Piso algorithm at 3e-4 of residuals. The model has an inlet (velocity inlet) and four outlet with flow split boundary conditions (outflow), and the flow is assumed laminar. Does anyone has suggestions on my problem? Many thanks |
October 23, 2013, 08:19 |
Try adjusting your relaxation factors
October 23, 2013, 17:13 |
salvatore
Rep Power: 16 |
Thank you very much for your suggestion!. I have decreased the under relaxation factor for moment to 0.1... should I decrease more?.... by the way, I will work on it and let you now... thanks
October 25, 2013, 13:09 |
Alex
Rep Power: 49 |
Maybe the assumption of laminar flow does not hold.
October 26, 2013, 06:48 |
salvatore
Rep Power: 16 |
I fixed it!!... apparently the problem was that I have split the mesh in several zones.... Once I have merged all fluids in the analysis, the solution converged rapidaly
CFL Condition | Matt Umbel | Main CFD Forum | 19 | June 30, 2020 09:20 |
[ANSYS Meshing] Problem with specifying first element size in 2D Mesh | sigmundab | ANSYS Meshing & Geometry | 9 | April 14, 2016 10:53 |
Pros and cons of the method of Space-Time Conservation Element and Solution Element | Dwayne | Main CFD Forum | 0 | October 11, 2013 08:43 |
Mesh element size | sunilpatil | Main CFD Forum | 1 | April 16, 2013 21:41 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 16:45 |
