October 18, 2013, 13:19 |
Request: horizontal axis wind turbine
Fadel El-Naamani
Hello guys I am new to this forum. I have a senior project and I am using ANSYS Fluent to simulate the wind turbine.
I am confused of how to start. I read a lot of tutorials and videos and do them but when I start with mine I lost. I want to make a wind tubine that rotate according to the speed of the winf hitting the blades showing this simulation. I tried to do dynamic mesh but I don't know if its correct. I tried to do UDF to allow the blades to rotor, also I don't reach what I need. I am reallly lost if you please help me how to start doing this. What I am sure of is that I must have a transient state. best regards thanks |
October 19, 2013, 09:19 |
Try rotating frame of reference concept which is done by rotating the whole domain with certain RPM while the air at certain velocity enter the domain, then measure the output torque, then calculate the power using it.
October 19, 2013, 12:44 |
Fadel El-Naamani
thanks mezah for your reply
but i need more details on how to start. In addition i only have the wind speed and i need the wind speed to rotate the blades not to assume the rotational velocity |
October 20, 2013, 15:43 |
I think this post here is very good starting point
http://www.cfd-online.com/Forums/flu...eshes-udf.html |
Horizontal Axis Wind Turbine | CFD XUE | FLUENT | 22 | May 24, 2017 13:17 |
2D Modelling of Horizontal Axis Wind Turbine | Richeom | Main CFD Forum | 1 | April 7, 2014 18:43 |
Vertical Axis Wind Turbine | atorninc | Main CFD Forum | 3 | March 6, 2013 05:38 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 16:46 |
OVERFLOW and Horizontal Axis Wind Turbine | ntonkin | Main CFD Forum | 1 | November 19, 2009 02:40 |
