RNG K-epsilon and wall function
Old   October 7, 2013, 09:53
Default RNG K-epsilon and wall function
Adhikar Hariram
PedFr0 is on a distinguished road
Hi All
I am currently investigating external flow around a heliostat with Re, based on the length of the heliostat, of around 3.5x10^6. I am using the RNG K-epsilon model for now as the Fluent documentation says that it can deal with rapidly strained and swirling flows, which is what I expect to encounter. Along with this model I am using the non-equilibrium wall functions as these are recommended for complex flows involving separation and impingement. I would like to know if this is the correct approach as I vaguely remember reading that the non-equilibrium functions are recommended for turbulence models that are valid near the wall, and I am uncertain as to if the RNG k-epsilon model satisfies this condition. Ideally I understand that I should be using enhanced wall treatment,which I plan to do at a later stage.
Many Thanks for your help
Adhikar
PedFr0 is offline   Reply With Quote
Old   October 14, 2013, 12:58
OJ
oj.bulmer will become famous soon enough
The non-equilibrium wall function is inherently an improvement over standard wall function (Launder/Spalding) in that it is sensitive to pressure gradient and hence the predicts the separation better. At the same time, it divides the wall adjacent regions into two layers. The inner viscosity dominated layer is treated with one equation model, while the outer turbulence dominated layer is solved using the k-eps or Reynolds stress transport closure. These are the only two closures available, and I don't think the model you are using has any bearing over the closures in these layers. I think RNG should be fine.
That said, when your physics starts having very severe pressure gradients or complex 3D flows very adjacent to the walls etc, these wall functions lose their relevance and no better than standard wall function.
OJ
oj.bulmer is offline   Reply With Quote
Old   October 14, 2013, 13:17
Adhikar Hariram
Hi OJ
Thanks for the reply, its really helped clear things up with regards to the wall function. I just have been having issues with enhanced wall treatment and am looking for the next best thing just for now.
Thanks
Adhikar
Old   October 14, 2013, 14:05
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
OJ
I want to add bit more
It is from theory guide
1. Launder and Spalding’s log-law for mean velocity is sensitized to pressure-gradient effects.
2. The two-layer-based concept is adopted to compute the budget of turbulence kinetic energy ( *, *) in the wall-neighboring cells.
Far is offline   Reply With Quote
Old   October 15, 2013, 04:49
Adhikar Hariram
Hi Far
Thanks for the reply, I've found the non-equilibrium wall treatments in the theory guide however I vaguely remember reading that it should only be used with models valid in the near-wall region but it looks like I was mistaken. Thanks for the help.
enhanced wall treatment, rngkepsilon, turbulence, wall functions
Wall function for velocity? johnblund OpenFOAM 3 September 6, 2022 08:22
in k-epsilon wall function approach high Re turbulence models: question of velocity romant OpenFOAM Programming & Development 6 May 26, 2016 10:14
Jump in epsilon values near the wall : low re k-epsilon model malaboss OpenFOAM Verification & Validation 1 February 1, 2013 17:36
SST model Autometic wall function parameters? David CFX 0 November 24, 2005 05:47
