Geometry for Confined Circular Jet
Old   October 1, 2013, 06:04
Question Geometry for Confined Circular Jet
Greatness is on a distinguished road
Attachment 25723
Attached is a proposed Geometry for (Fluent simulation) for a turbulent confined circular jet.
Attachment 25723
The jet is actually circular, so I guess the cross-section for both the nozzle & duct should be cylindrical. I used Ansys Workbench for the Geometry building & Meshing, and also changed 3D to 2D from the 'geometry property'. In the course of building the geometry, I had the following problems:
1. I created the nozzle & duct section using cylinders (from 'create - Primitives - Cylinder'), but in the course of taking it into the mesh, it says "No valid 2D bodies". But, when I changed the 'GEOMETRY PROPERTY' to 3D, it accepted it. Please what could be responsible? Is it because of the way the cylinders were created? If that's the reason, how else can we create the geometry such that the nozzle & duct will have circular cross-section?
2. I found it difficult to introduce the 'centerline' & 'tangential separation surface' as named selections which will be seen in the 'Boundary condition section' of the Fluent solver. Please how do I need to introduce this regions for the simulation to see it & work with it?
Thank you.
Greatness is offline   Reply With Quote
confined circular jet, fluent
2D Plane Jet Fluent Solution doug Main CFD Forum 11 February 4, 2019 10:34
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Jet in Supersonic Crossflow, controlling mass flow rate ChrisA OpenFOAM Running, Solving & CFD 3 November 13, 2012 19:20
Help Needed in Geometry for jet Array impingement in Cocentric Tube Annulus Excel Main CFD Forum 1 April 18, 2010 11:31
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
