September 29, 2013, 06:35 |
Air at High Pressure
Rep Power: 20 |
Hi Dear fellows
I am trying to model the Air Reducer/Pressure Reducer in Fluent. The Inlet pressure is 250 bars and mass flow rate is 0.36 kg/s. The desired outlet pressure is around 8-9 bars. I am using Pressure inlet boundary condition @inlet and Mass flow inlet boundary condition @outlet(with appropriate direction vectors so that mass flow out from the outlet). Since air is compressed at high pressure of 250 bars so Ideal gas model cannot be used. I have read that due to high variation of temperature from inlet to outlet Peng-Robinson Real Gas model should be used instead. But when I set this model in the materials panel for air and compute Reference values from the Inlet boundary, the density reported is very very less i.e of the orders of 10^-5. In actual scenario the density is high(around 300 kg/m^3) due to high pressure at which the air is stored in air bottles. I don't know what mistake I am making....if any body has done such problem or has handled air at high pressures or used real gas models for air in Fluent kindly help me. Thanks in advance. Regards |
September 30, 2013, 08:49 |
like.no.other
Rep Power: 15 |
Hi
I think you should use able-noble EOS in High pressure and temperature flow |
September 30, 2013, 15:58 |
Rep Power: 20 |
Thanks for your reply.
Can you tell me what's the specialty of this model? |
chtMultiRegionFoam solver application for high velocity& High Pressure | xiaoyoyo | OpenFOAM | 2 | July 25, 2013 12:50 |
how to replace a shock tube high pressure port by a boundary condition? | immortality | OpenFOAM Pre-Processing | 0 | May 2, 2013 14:43 |
Simulating movement of air from low to high pressure in Fluent | jwillie2000 | FLUENT | 0 | April 11, 2013 05:18 |
Simulating a high pressure flow through a valve | Kromagnsss | FLUENT | 8 | July 2, 2010 06:20 |
Properties of air versus temperature AND pressure | Vincent | Main CFD Forum | 5 | July 28, 2008 07:28 |
