Heat transfer in rooms: laminar or turbulent?
Old   September 18, 2013, 05:55
Default Heat transfer in rooms: laminar or turbulent?
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Goodmorning all!
I'm studying a problem of heat transfer in 2 adjacent rooms (air inside) separated by an insulation wall (domain dimension: heigh=9 m, width=36 m).
Left room has an avarage temperature of +5 ˚C, right room is at -22 ˚C.
Inside there is air and Boussinesq approximation was used.
All the walls are adiabatic, except for the floors which have a temperature equal to the mean room temperature and for the insulation walls which are coupled walls.
My case is 2D.
I tried different models:
- laminar
- turbulent, standard k-e with scalable wall function
- Transition, SST (y+<=1)
I have to calculate heat transfer coefficient for the left room.
The parameter for the choice of laminar or turbulent model is the Rayleigh number (for vertical wall it should be turbulent for Ra>10^8).
In my case, for the left room I have Ra=9,8*10^10, so it should be turbulent.
Results:
- laminar simulation: the problem is not steady, in the left room I have 2 macro vortices and smaller vortices which are created and dissipated.
Area average temperature of the room: 278,126 K
Area average temperature of the insulated wall: 276,447 K
Heat flux, from left room through the insulated wall: 2,534 W/m2
h=1,510 W/m2/K
- Turbulent and transition: the problem is steady; no smaller vortices are created.
k-e model:
Area average temperature of the room: 278,133 K
Area average temperature of the insulated wall: 277,813 K
Heat flux, from left room through the insulated wall: 2,301 W/m2
h=7,199 W/m2/K
SST model:
Area average temperature of the insulated wall: 277,829 K
Heat flux, from left room through the insulated wall: 2,530 W/m2
h=8,310 W/m2/K
Literature correlations gives low value of this heat transfer coefficient...what do you think?
I'm attaching some pictures of velocity distribution.
Thank you,
Daniele
ghost82 is offline   Reply With Quote
Old   January 16, 2014, 03:41
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Ciao Daniele,
Could you please show the setup for this simulation (solution methods, solver,...) ?
I usually work on radiators in room: I suggest using RNG-k-epsilon turbulence model (even if the my usual temperatures are different)
Regards
Bionico
Bionico is offline   Reply With Quote
Old   February 13, 2014, 09:47
ghost82's Avatar
Rick
Originally Posted by Bionico View Post
Ciao Daniele,
Regards
Ciao Flavio,
sorry for delay in my reply..
I deleted these simulations some months ago as the main simulation was a big warehouse to study air circulation with different fan configurations.
I made the above preliminary simulations to try to find a heat transfer coefficient to input as boundary condition in the main simulation.
However, since I obtained very different results I decided to directly input the transferred heat, calculated with classical simple equations.
As I remeber, for these preliminary simulations I adopted no particular setting, I retained the default ones, changing only methods to second order upwind.
PS: yes, for the main simulation I used RNG k-epsilon model with scalable wall functions.
Also I couldn't obtain a stable solution for the stationary solver and I had to switch to the transient one, obtaining good results.
Solver for an incompressible, turbulent flow with heat transfer tH3f0rC3 OpenFOAM Running, Solving & CFD 9 June 17, 2019 07:12
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
Radiation interface hinca CFX 15 January 26, 2014 18:11
Looking for a solver (Mach 0.4, Turbulent, Heat Transfer, Second Order) fredo490 OpenFOAM Running, Solving & CFD 3 March 27, 2013 05:07
Heat transfer coefficent in turbulent flow Ola Lindgren Main CFD Forum 2 November 17, 1998 06:49
