September 8, 2013, 02:12 |
Regarding Species Transport for Diffusion
chia chun
Rep Power: 13 |
Hi there,
I am trying to simulate an ion diffusion process through a nano-channel using Species transport model. I have created a mixture of CO2 and water with water being the bulk species and set up a concentration gradient of CO2 across the top (inlet) and bottom (outlet) of the channel. The inlet velocity is set to 0 as i do not want any convective fluid flow, only pure diffusion. When i run the process, i realised that both CO2 and water are diffusing through the channel at the same time (which is expected). My main concern is how do i allow only CO2 to diffuse through while making water as the background stationary fluid in the channel where CO2 will travel. Does anyone know what should i change in the setup? I tried removing water from the species mixture, leaving only CO2. but by doing so, i could not set up a concentration gradient under the boundary conditions of inlet and outlet. Can anyone provide some advice here? Thanks in advance! |
Modelling Biomass Combustion via Species Transport | Racheal | FLUENT | 39 | January 8, 2022 08:42 |
Fixed Bed Gasifier, Species Transport Problem | therandomestname | FLUENT | 12 | January 4, 2019 08:08 |
Please help!! Patch and Species transport | Julie | FLUENT | 5 | August 3, 2016 04:10 |
questions about species transport through walls | shuqin | FLUENT | 13 | April 9, 2014 03:42 |
Implement species transport equation | Tobi | OpenFOAM Programming & Development | 0 | June 2, 2012 14:26 |
