PDF table- species adding problem
Old   September 6, 2013, 07:53
Question PDF table- species adding problem
shacharbala
shookybal is on a distinguished road
Hello
I am trying to create a mixture with one inert species which can only change phase. therefore I created a species called Zz which consists of one atom of Zz in thermo.db file and in thermodb.scm. It has all the other parameters of the non-inert specie.
I get the following error when trying to compute PDF table:
__________________________________________________ _____
Generating PDF lookup table
Type of the PDF Table: Nonadiabatic Table (Two Streams)
Calculating table .....
calculating temperature limits .....
Error: get_bc_species: no boundary species defined
Error Object: #f
what am i doing wrong? please help me to solve the problem
Thanks,
Shookybal
shookybal is offline   Reply With Quote
Old   October 21, 2019, 11:04
subhankar
SUBHANKAR is on a distinguished road
I am facing the same problem. If you have solved that issue, can you please guide me. I am trying to add toluene to thermo.db.
regards
Subhankar
SUBHANKAR is offline   Reply With Quote
Species transport model problem argeus FLUENT 8 September 20, 2019 08:23
Problem when adding temperature to interFoam houkensjtu OpenFOAM 4 November 5, 2012 03:35
Species Transport Problem Deside FLUENT 3 March 12, 2010 14:58
Problem with pdf reading(unable to get properties) João Pimentel Main CFD Forum 0 September 11, 2006 09:49
adding constant number to a table Ossi Kaario Siemens 0 March 13, 2001 13:23
