Discretization Scheme
Old   August 31, 2013, 05:52
Default Discretization Scheme
Vjoess
dinesh is on a distinguished road
I am using PISO scheme and Body Force weighted for Pressure correction. Also my analysis is transient. I need to run simulation to get result of 12hr duration. So i am using Adaptive time steping. But i could not understand two things
1. the iteration run for only one time. It does not show whether the solution is converged. By looking at the residuals i have to interpret the solution has converged or not. Is it normal with this scheme.
2. With adaptive time scheme i hope to get a time step of 10s so that my results come faster(as i require 12 hr of result) but when i am using the above scheme my time step goes to 1e-5 order. What should i do to improve this time step.
My domain is 1m long cylinder with another tube passing through it having dia 54mm. Outer dia of cyl is 0.6m, i have 8lac cells in the domain.(Phase change analysis)
my mesh file is in the link
https://www.dropbox.com/sh/8saox6nt7nke788/Q2eS9GHwa7
dinesh is offline   Reply With Quote
TVD scheme in unstructured finite volume discretization abcdef123 Main CFD Forum 2 January 16, 2013 01:26
Time discretization scheme HaKu Main CFD Forum 1 June 12, 2011 03:06
Discretization scheme for Convection Terms Mohammad Kazemi CFX 16 December 7, 2004 23:38
Discretization scheme: whih one is good in my case Julie Polyakh Siemens 3 June 24, 2003 21:27
MARS discretization scheme raymond Siemens 3 February 1, 2002 06:33
