August 28, 2013, 11:49 |
Converged solution changes upon restarting
athan
Hello:
I am using ANSYS FLUENT v14.0. i am solving a steady-state, fiber coating problem in a fairly complex geometry with surface reactions. The equations solved are momentum, energy and a few species concentrations. For the low diffusivity cases (low operating tempeartures) I seem to get converged solutions (residuals are very low and plateau out). But when I restart, the converged solution changes: the residuals spike and then they plateau out! This does not happen when diffusivities are high (high T). Any ideas/suggestions as to why the solution gets 'trapped' in an artificial converged state for the low diffusivity cases? I am using 'coupled' pressure-velocity coupling with second-order upwind. Thanks athan |
steady-state convergence |
simple solution converged in 9 iterations? | Gabbee90 | OpenFOAM Running, Solving & CFD | 4 | January 29, 2019 21:04 |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
smoothSolver diverges - solution in using PBiCG solver? | makaveli_lcf | OpenFOAM Running, Solving & CFD | 3 | September 11, 2013 12:44 |
solution is not getting converged | Nijanthan | FLUENT | 5 | July 25, 2013 01:42 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
