pathline difference in fan for 1 order and 2 order scheme
Old   August 25, 2013, 12:07
Default pathline difference in fan for 1 order and 2 order scheme
thomasesel
tongnan is on a distinguished road
Hi, I am trying to simulate a fan. In my case, the full 3D fan is modeled with the casing together.
The upstream of the fan is an air chamber and set as pressure inlet 0 Pa. the downstream is set as pressure outlet 0 Pa. The rotating fan is set as MRF. SST model is used.
At first, the rotating speed is increased step by step, the first order upwind for k, omega and momentan equations and 10 times smaller under relaxation factor are used. The pathlines are reasonable, figure 1. Then, the calculation runs under 2 order upwind, but the pathlines are greatly differnce from the figure 1, s. figure 2. It seems the blowing of the fan does not continue.
Can anyone tell me the possible reasons for the simulations?
Thank you in advance!
tongnan is offline   Reply With Quote
Old   August 27, 2013, 16:31
thomasesel
does anyone have an idea?
thank you!
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 13:29
Difference between first order and second order msatrustegui FLUENT 2 December 5, 2012 06:54
2nd order boundary conditions for 2nd order discretization? quarkz Main CFD Forum 30 December 26, 2011 08:12
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 02:50
High order difference scheme for KIVA3v2??? LiQiang Main CFD Forum 1 May 9, 2005 14:50
