FLUENT received fatal signal (ACCESS_VIOLATION)
Old   August 23, 2013, 06:01
Question FLUENT received fatal signal (ACCESS_VIOLATION)
Pengianlei
LemonPeng is on a distinguished road
Hi everyone,
I met an odd problem when using Fluent 14.0. I run a simple case in our workstation (Win7 64bit OS) in parallel processing. But it always interrupt with:
Error:
Parallel FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
However, when I ever run the same case with Fluent 13.0 in the same machine, this error didn't happen. Also, I run this case with Fluent 14.0 in my PC (Win32 OS), there is no such error issues.
Now I want to know how to overcome this error in Fluent 14.0. Is there somebody kindly enough to provide any suggestions.
Thanks
LemonPeng is offline   Reply With Quote
Old   August 27, 2013, 04:24
Question
Pengianlei
Is anyone kindly enough to help me?
Originally Posted by LemonPeng View Post
Hi everyone,
Error:
Thanks
Old   August 27, 2013, 17:48
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Do you use UDF in you simulation?
If yes, you've probably using UDM and you forget to launch them before keep running.
Regard yours
A CFD free user is offline   Reply With Quote
Old   August 27, 2013, 21:36
Pengianlei
Hi "A CFD free user",
Thanks for your reply.
In my case, UDF is not used. And the case always interruts after hundreds time-steps.
Old   August 28, 2013, 06:49
A-A Azarafza
Hi
I actually encounter this error when I forget to run UDM before I start simulation. Maybe there is problem regarding the boundary conditions. Once I had a problem the same as you when I working on a axisymmetric stirred tank and I wouldn't notice to the hint in user guide concerning the right selection axis for rotation! You might have a look at the B.C again to be sure that you used them appropriately.
Regard yours
Old   September 3, 2013, 07:42
Smile
Pengianlei
Hi everyone,
It seems I find the reason for my problem.
To get rid of all possible reason, I unistall all other softwares in my Workstation, and then install the Ansys angin, the error doesn't occur. Even though I don't know which exactly software is incompatible with Fluent, it may provide some advice for someone facing the same error.
Hi
access_violation, fluent 14, win7 x64
FLUENT received fatal signal (ACCESS_VIOLATION) CHAKER FLUENT 4 December 11, 2015 04:20
FLUENT received fatal signal (ACCESS_VIOLATION) Mike Wong FLUENT 7 October 17, 2014 14:17
FLUENT received fatal signal (ACCESS_VIOLATION) rubis Fluent UDF and Scheme Programming 6 April 22, 2014 16:42
fatal signal (ACCESS_VIOLATION) manu FLUENT 0 December 10, 2007 07:10
FLUENT received fatal signal (ACCESS_VIOLATION) samy FLUENT 0 November 10, 2007 14:09
