Hydraulic diameter for multiple ducts
Old   August 23, 2013, 02:45
Default Hydraulic diameter for multiple ducts
Jalay Shukla
jalay is on a distinguished road
I am making a simulation of gas diffusion in room.
In which continuous air is coming from 4 ducts and 4 exhausts are there and gas is introduced from some place inside the room.
I have used k-e model with realizable and with buoyancy effect. Is this correct for this simulation?
And what should be the hydraulic diameter for 4 ducts? Do i need to make 4 individual inlets and give BC to them OR can i give BC to all at single BC,by multiple selection. and what should be the hydraulic diameter that case?
jalay is offline   Reply With Quote
Old   August 23, 2013, 03:34
Paritosh Vasava
vasava will become famous soon enough
It is advised to keep your inlet and outlets individual and not bunch them in to groups. So you can keep the 4 inlets and 4 outlets separate and calculate hydraulic diameter separately for each inlet and outlet.
vasava is offline   Reply With Quote
Old   August 23, 2013, 05:17
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
It depends on the mesh model. If your inlets are not connected before entering the room then you should set BC for each inlet. If you are using circular cross section of pipes then pipe diameter is the hydraulic diameter, else there is a good formula to calculate it.
Philipov is offline   Reply With Quote
Hydraulic Diameter - Series of Holes Jop FLUENT 6 January 14, 2019 10:41
equivalent diameter vs hydraulic diameter swamysrikanth FLUENT 1 October 12, 2013 02:18
[GAMBIT] hydraulic diameter? Zweeper ANSYS Meshing & Geometry 6 January 4, 2010 01:44
hydraulic diameter in 2d ahsan FLUENT 2 August 28, 2009 16:22
Importance of Hydraulic Diameter Value for Compressible Flow RyGuy FLUENT 0 August 6, 2009 11:58
