convergence of propeller blade velocity
Old   August 21, 2013, 08:35
Post convergence of propeller blade velocity
vishal
dnb2289 is on a distinguished road
hallo everyone!!
from last one month i have started working on fluent and my goal is to get convergence of propeller blade velocity.I have tried by changing controls from solver also but my solution is almost remain constant after 100 iterations and its not getting converged .so i need your help.so let me know how should i proceed now??
Thanks & Regards,
Vishal
dnb2289 is offline   Reply With Quote
Old   August 21, 2013, 16:09
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hello there
If there is no problem concerning the geometry (model and mesh quality) and boundary conditions, then you need to increase the velocity gradually. For instance, if you want to run a impeller with 200 rpm, then first start with 30 rpm and increase it 20 rpm step by step and in each step, try to get a converged solution. Be careful to apply right turbulence model as well.
Good luck
Regard yours
A CFD free user is offline   Reply With Quote
Old   August 22, 2013, 06:08
vishal
hallo ,
Thank you for reply and so now let me try this method and if i would have any problem then will let you know,
Best Regards,
Dharmesh
Old   August 22, 2013, 06:41
Paritosh Vasava
vasava will become famous soon enough
Some questions:
1. What approach are you using? Moving frame of reference, dynamic mesh or something else?
2. Is your simulations steady-state or transient?
3. What makes you say 'my solution is almost remain constant after 100 iterations and its not getting converged'? Are you observing a particular quantity or Convergence graph?
Few pictures from your mesh and results would also help us help you.
vasava is offline   Reply With Quote
Old   August 22, 2013, 08:18
vishal
Hallo Vasava,
Description of My task: I am working on propeller blades of helicopters and i have to get convergence of three types of blade inlet velocity and my approach is Absolute reference frame and my simulation is for steady state condition. and velocity and mass flowrate i set same in all three blades ,in one old wood blade i got convergence and in one blade after trying many times the convergence not coming near to criteria but its going up and up and in one blade convergence remain almost constant after 100 iterations ..My main goal is to get convergent solution of inlet velocity of all blades .i have checked mesh and everything and my supervisor also checked .I don't know how to take photo so tell me how can i click and send .
Thank you
Best regards,
vishal
propeller convergence
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Reference Velocity Calculation & Convergence Problem hasan_hzl Main CFD Forum 0 January 29, 2011 14:42
Inlet Flow Velocity or pressure gradient - modeling of a Wind Turbine Blade case LittleBart Main CFD Forum 5 January 10, 2011 16:07
Ultra slow convergence velocity in the simulation demigod FLUENT 1 October 5, 2005 09:03
propeller rotating at zero inflow velocity Ammu FLUENT 1 July 23, 2005 14:36
