Boundary condition for Natural convection
Old   August 21, 2013, 08:30
Default Boundary condition for Natural convection
rabbi tonmoy
tonmoy is on a distinguished road
My project is laminar free convection over a vertical plate.
my domain is 100x100 cm and body size 2x6 cm
may be I face problem for setting boundary condition.
I set boundary condition as-
1.Inlet at the bottom (pressure inlet)gauge pressure 0 pa, and intial pressure 0.inlet temp 275k
2.outlet at the top (pressure outlet) gauge pressure o.back flow temp 275k.
3. object (wall). convection-Heat transfer coefficient-25, body temp 325k
4.symmetry(right and left portion) of domain
operating condition 101325 pa, gravity on,operating density on (1.225)
I face problem in reversed flow.
Is there something I am missing in setting up the pressure boundary conditions?
please give a solution for overcoming this problem
tonmoy is offline   Reply With Quote
Old   August 21, 2013, 10:37
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
The reversed flow WARNING only indicates that at some faces, the fluid flows in the opposite direction (out of the domain at the inlet or into the domain at the outlet).
If you think about the flow field that is prodced by a heat source especially if the flow is turbulent, a backflow is very likely.
You could try to initialize the flow field with a small velocity pointing in the right direction. But if the reversed flow warning appears again this is most likely the correct physical behavior of the flow.
Edit: The assumption of laminar flow might be wrong. How did you get to this conclusion?
flotus1 is offline   Reply With Quote
Old   August 25, 2013, 09:58
JAY
JAY ADHVARYU is on a distinguished road
I have some problem with my boundary condition that how i utilize the neumann condition(∂φ/∂x = 0) at outlet. Can i select pressure outlet at outlet?
my inlet condition is :
flat velocity profile =40m/s
Re=1.916*10^5
turbulent intensity=4.5%
And Inlet height of duct=5mm
I select velocity inlet at inlet because my flow is incompresible.
And axis boundary condition applied along the centerline.
and no slip condition at wall.
pls help me.
JAY ADHVARYU is offline   Reply With Quote
Time dependant pressure boundary condition yosuke1984 OpenFOAM Verification & Validation 3 May 6, 2015 07:16
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Convection Boundary condition tomcatbobby FLUENT 2 April 30, 2012 14:50
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 01:55
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
