Combustion does not occur in EDC model
Like Tree12Likes
Old   September 18, 2014, 11:35
zdx
zhuoyue89 is on a distinguished road
thanks for your reply,i'll try it later,now i have to prepare to sleep,good luck.see you.
zhuoyue89 is offline   Reply With Quote
Old   September 18, 2014, 11:36
Andrea
Andrea1984 is on a distinguished road
You are welcome, good luck with your modeling
Andrea1984 is offline   Reply With Quote
Old   October 21, 2016, 04:12
Default EDC combustion
  #23
Arun M
arunm is on a distinguished road
How five step combustion of Ch4-air can be included? Is it necessary to go for Chemkin mechanism files if it is not in Fluent.
arunm is offline   Reply With Quote
Old   August 8, 2017, 03:08
sooraj546 is on a distinguished road
can any one help me out with this in FLUENT
I want to know what is the value of 'i' (index) so that I can use C_YI (c,t,i). I have number of species mixture for combustion i am using EDDY DISSIPATION MODEL. So how can I count for species index?
sooraj546 is offline   Reply With Quote
Old   October 4, 2018, 11:26
Default Run Transient on steady Combustion.
  #25
Ali Haider
hahs is on a distinguished road
Run simulation in steady case for appropriate time after this, change steady to transient. if u have problem with transient combustion and if your combustion is not working in steady case then go to solution controls>advance Solution Controls>Expert and then enable the elements in expert tab and gave appropriate values, may be 10. Pseudo Transient must enable in Solution Methods.
hahs is offline   Reply With Quote
Old   December 24, 2018, 07:29
atelcikti1's Avatar
atelcikti1 is on a distinguished road
After initialization with EDM solution, if you get no combustion, unfortunately you will never ever see combustion. Probably your flame is blowed-out.
maziar77 likes this.
atelcikti1 is offline   Reply With Quote
Old   December 7, 2019, 06:21
Ruchit Patel
ruchit@15847 is on a distinguished road
@Andrea1984 I am trying to study the combustion in igniter using kerosene - oxygen both coming from a separate stream. I want to use the EDC model for getting the temperature distribution on the igniter walls. So, as per the ANSYS Fluent user guide, I am running the simulation using species transport model with a non-premixed model of combustion for 600 iterations. Then I am using this solution as an initial solution for the EDC model. But as the simulation is going with the EDC model, the temperature is decreasing continuously and settled up with 300K which is the inlet temperature of both kerosene and oxygen. I don't know what's going wrong with the EDC model. Can u please guide me?
ruchit@15847 is offline   Reply With Quote
Old   December 8, 2019, 17:48
Andrea
Hi Ruchit, sorry but it has been quite a long since I have been working on this. Does combustion take place when you use the non-premixed flamelet model?
Andrea
Old   December 9, 2019, 02:18
Ruchit Patel
@Andrea1984 Thanks for the reply.
Yes, Combustion is happening in the domain as I can see the products and other radicals formed and the highest temperature is around 2400K up to 600 iterations but it was showing "the highest pdf enthalpy exceeded in some cells" during running the simulation with the non-premixed model.
Old   December 9, 2019, 06:09
Andrea
As I said I'm a bit rusty on the subject, but in my experience EDC was working fine when initialized from the results obtained with a flamelet model.
Do you have heat losses in your case? Maybe try an adiabatic run first?
Old   December 9, 2019, 06:44
Ruchit Patel
Does the flamelet model mean a steady diffusion flamelet model? I am running the non-premixed model with chemical equilibrium.
Old   December 9, 2019, 07:13
Andrea
My case was actually partially-premixed so I was using the partially premixed model with premixed flamelets to generate my initial condition. Anyway any initial condition with a reasonable temperature and species distribution should work.
Old   May 27, 2022, 18:34
maziar gheshlaghi
maziar77 is on a distinguished road
hi. i have same problem. no combustion with EDC.
maziar77 is offline   Reply With Quote
combustion, edc, fluent
combustion model in premixed combustion chamber wuyu FLUENT 9 February 16, 2018 11:40
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
EDC model Carl FLUENT 0 November 11, 2008 22:36
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 06:24
can alternate combustion model by UDF? Han Xingsi FLUENT 0 September 1, 2008 03:08
