How to keep the water level constant at inlet |
Tanjina Afrin
Rep Power: 13 ![]() |
Hello all,
For keeping the water height constant at inlet, which BC should I use when I don't know the mass flow rate ( for mass flow rate inlet) and velocity ( velocity inlet) ? I used pressure inlet, but from static pressure contour , I found negative pressure at inlet portion. I am using multiphase ( VOF) model . It will be great help if anyone can suggest me anything. Thanks in advance. |
Stephan Langenberg
Rep Power: 14 ![]() |
You want to establish a constant water level? I think you have to possibilities (based on your model and settings).
The easy one is working with profiles for the inlet (non constant velocity and non constant mass inlet). -> If you can calculate your massflow. The other way is using UDF for your inlet. You may set a pointer for (pressure, velocity, VolumeFraction) on a Cellzone or face and regulate your inlet velocity by it. I imagine something like a sensor for the volume fraction. If the Volume fraction in one cell is higher than X (because of raising water level) the pointer activates a clipping function in the inlet and reduces or stopps the velocity inlet. What I don't know without using the manual is how to point pressure or an other value in a seperate cellzone, but I've read it ones. |
#3 | |
Tanjina Afrin
Thank you very much for your reply. you know any way that I can calculate mass flow rate ? I am working with 2D and 3D both. Unfortunately, I couldn't understand your UDF part. can you explain a little bit ? Thanks in advance. ![]() |
Stephan Langenberg
I don't know your model, so I can't say if you can calculate your needed mass flow inlet. If it is a easy model you can calculate with analytic and use fluid mechanics...
The UDF is a function written to adapt the flow inlet to a a criteria you choose. In an experiment you could set an sensor in a position X, when the water level arrives the sensor he would give a signal and regulate the inlet. An UDF has the possibility to do the same in your numeric system. The sensor could be a pointer and activate a function (maybe stop velocity inlet) if a physical value (temperatur, volume fraction etc.) reachs a special magnitude. Hope my Position is clearer now. |
#5 | |
Tanjina Afrin
Thank you very much . My model contains two part. One is filled with gravel and water will pass through this porous zone to a pipe. I want to keep water height constant at this porous region. I don't have any discharge or velocity data. So is it possible to calculate mass flow rate here? And about UDF, now I am reading UDF manual fluent. Hopefully, after reading some example , I will be little bit familiar with it. Thanks for your generous help. ![]() |
#6 | |
Rep Power: 17 ![]() |
To set a constant height at inlet area, you may try to split the domain to two. set the volume fraction of the sub-domain which includes inlet BC as fixed value (=1). But first you have to make sure that such a setting is physically correct. |
Tanjina Afrin
Hi John, I am sorry that I just missed the notification that someone has answered my query. I am not sure how to split the domain to two, but as a normal VOF model, Inlet had three phase, one is water, one is air and third one is mixture. I allowed to water volume fraction =1. From the volume fraction of water contour shows that water level is constant, but from static pressure contour I found that there are negative pressure just below the inlet with a magnitude of -84 pascal. So I got worried. Do you have any idea about that ?
anonymous
Rep Power: 15 ![]() |
Have you used specified operating density option with the density of lighter phase.
#9 | |
Tanjina Afrin
My problem is somehow solved now..... what I did wrong there is I plotted the contour with static pressure. After plotting the total pressure, pressure is zero at inlet, which means that water level remains constant. |
#10 |
Alireza Bahmanpour
Rep Power: 12 ![]() |
Hi Tanjina,
Could you please clarify more how you solved your problem? I also need to set my inlet flow level to be constant. Thanks, Ali |
#11 |
Tanjina Afrin
Hello AliRezab,
I had two type of settings. For one case, I had side inlet (water entered into the domain from side) and I needed to top water level of the domain be constant. For that case, I used symmetry boundary condition, which means I forced the domain's water surface to be constant. And for another case, I had top inlet (water entered into the domain from top) and again I needed top water level be constant. That case, I used pressure inlet with zero pressure. Reference pressure was atmospheric pressure. Hope it helps. Regards, Tanjina |
inlet bc, vof |
How to estimate water level in two phases channel flow? | apollo11ho | CFX | 2 | July 18, 2012 09:34 |
[swak4Foam] Trouble setting groovyBC interFoam Inlet BC | mgdenno | OpenFOAM Community Contributions | 4 | July 1, 2012 08:16 |
Constant gauge pressure inlet | yan | FLUENT | 1 | June 3, 2005 12:13 |
Patching of a constant value at inlet | Chimwemwe Banda | FLUENT | 1 | January 5, 2005 01:44 |
