turbulent juncture flow around cyl mounted on flat plate |
August 12, 2013, 17:30 |
anonymous
hi there
I am simulating turbulent juncture flow around a cylinder mounted vertically on a flat plate in fluent 14.0, and range of Reynolds number is 8000-100000 I need few guidelines what time step size should i use to get a converged solution and how to calculate step size ? which viscous model is better to use for this range ? what steps should i follow to get better results ? mesh size is 2.18 million |
time step size |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Flow over a flat plate as an immersed solid | hamed.majeed | CFX | 4 | September 8, 2016 14:40 |
problem in turbulent flow over flat plate with stagnation point | mb.pejvak | Main CFD Forum | 0 | September 12, 2012 21:25 |
Experimental Results for turbulent flow over a flat plate | mb.pejvak | Main CFD Forum | 0 | May 18, 2012 22:20 |
Supersonic flow over flat plate - best model | Chris Rand | FLUENT | 4 | October 3, 2000 06:58 |
