August 24, 2013, 06:57 |
#21 |
Davide
Rep Power: 14 |
Thank you very much for these settings!!!
Can i ask you the settings you have used for the residuals? I have set them up to 1e-10 and with k-epsilon model the simulation converges in 2300 iterations... |
August 24, 2013, 07:07 |
#22 |
Alex
Rep Power: 49 |
I usually disable residual targets for such simple simulations and run the cases until the residuals level out.
August 7, 2014, 14:57 |
Is this a correct implementation of resolve TKE
#23 |
Charlie
Rep Power: 16 |
Is the below implementation equivalent to TKE = 1/2*[bar(u'u')+bar(v'v')+bar(w'w')]
0.5*magSqr(cmptAv(U-UMean)) It is not identical to the K I get from k-epsilon, but this a modelled term so I didn't know if they should be identical. Any feedback is greatly appreciated or any suggestions as how to solve for the resolved TKE in LES models or URANS. |
turbulence kinetic energy |
How to exclude UDFs and turbulence kinetic energy source terms? | bryanwly | Fluent UDF and Scheme Programming | 0 | May 22, 2011 14:01 |
Mean Kinetic Energy | alastormoody11 | STAR-CCM+ | 1 | January 19, 2011 10:48 |
LES of periodic pipe centerline turbulent kinetic energy | smehdi609 | OpenFOAM | 0 | December 1, 2010 00:59 |
Maths problem when deriving conservation of energy equations. | Demonwolf | Main CFD Forum | 1 | June 15, 2009 15:21 |
what's the macro of SGS turbulent kinetic energy? | lcw | FLUENT | 1 | June 13, 2006 04:08 |
