save lift and drag convergence histories in fluent14 |
August 8, 2013, 16:27 |
Ali.E
Rep Power: 16 |
Hello my friends,
I work with Fluent 14 and I want to save lift and drag convergence histories; I have used the monitor option and acted write option too. Therefore, two files have existed but only result of present time is saved in the files and actually, I lost the result of other times steps. Do you have any solution for it? I want to save all lift and drag coefficient in the files according time to plot convergence history. |
August 8, 2013, 16:52 |
Rep Power: 13 |
Hi!
if u want to plot Cd or Cl per iteration history, i have a solution for u. go to monitors and create Drag. in opened dialog box, active Write and then type .txt in front of the file name. finally go to work directory and from dp0 > FFF > fluent, u can access iteration history in a txt format. Good luck! |
August 8, 2013, 16:59 |
per zone in ansys fluent 14
rasoul b
Rep Power: 15 |
Hi, dear friends
i have two surface and i want to monitor drag history per time. when i use per zone tick, the written data is separate but graphical fluent show average of two. i.e. two curve displayed in one average curve. can anyone help me. thanks |
August 8, 2013, 18:44 |
#4 | |
Ali.E
Rep Power: 16 |
Hello again
I did do as you said but the problem is that only one Cl per last iteration is saved in the generated txt file. All of text in the file is as below: "Lift Convergence" "Flow Time" "Cl" 2.58750e+00 6.19072e-01 but I need Cl per every iteration. May I make any comments for this problem? cheers, Quote:
August 9, 2013, 04:22 |
Rep Power: 13 |
you should do it before starting to solve!
October 22, 2018, 04:38 |
Rep Power: 8 |
Hi, I am using fluent v19.1 and saved Cd and Cl data files but when I tried to open, these were not saved as .dat files and are opened only in MS word. I copy them and investigated results. But I want to know why files were not saved in .dat form. Thank you!
October 22, 2018, 10:27 |
#7 | |
Lucky
Rep Power: 66 |
They are basic ascii text files always no matter what. If you want the name to end in .dat then specify it has filename.dat when you create the monitor/report. Btw, in my opinion, .dat is not the best extension to use if you want to distinguish between file types because that's the same extension as the fluent .dat file where the solution data is stored. |
[OpenFOAM] Display lift and Drag in paraview | SamerAli | ParaView | 1 | May 16, 2013 13:51 |
How to see lift convergence and drag convergence history graphs ? | abhiprayj | FLUENT | 0 | March 17, 2012 18:40 |
Lift and Drag Monitor Point Values Converging to Zero | Josh | CFX | 24 | May 9, 2011 11:38 |
convergence criteria by lift and drag coefficent | xtof | CFX | 3 | March 18, 2011 15:38 |
Correct lift but wrong pressure drag - possible? | zx | Main CFD Forum | 4 | July 28, 2007 00:38 |
