Aeroacoustic signals off by 20-30db compared to experimental data
Old   August 6, 2013, 19:15
Default Aeroacoustic signals off by 20-30db compared to experimental data
zbyhu is on a distinguished road
I am doing a noise simulation of an isolated airfoil, and when I looked at the results today they seem to be off by 20-30db. By character the plots are the same for experimental and cfd data, just offset. Do you know if there is something I might be forgetting about that is causing this?
Also it looks like the signals calculated in Fluent have to be A-weighted before being compared with microphone data, is that right?
I've uploaded some plots for reference here: http://imageupper.com/g/?S020001004U1375827073108508
(the ones where the SPL is higher are from the experiment)
edit: And here are all on one: experiment, simulation, simulation after a-weighting, and with +30dB.
zbyhu is offline   Reply With Quote
Old   July 17, 2020, 14:08
Default Similar problem
cfduser99 is on a distinguished road
Were you able to solve this problem? If yes please tell us about it.
Thank you.
cfduser99 is offline   Reply With Quote
Step Changes in Roughness Experimental Data syler3321 Main CFD Forum 0 October 20, 2010 01:45
Functions to import non grid associated experimental data benk OpenFOAM 1 June 30, 2010 06:11
fan vs experimental data ijk CFX 2 June 7, 2010 05:42
Multiphase experimental data James McLaren Main CFD Forum 1 September 14, 1998 07:35
Finding Experimental Data Mattias Jaran Main CFD Forum 0 August 10, 1998 08:35
