Periodic Boundary Condition on Impeller Section
Old   August 6, 2013, 14:27
Default Periodic Boundary Condition on Impeller Section
RacMat
rvl565 is on a distinguished road
I have a impeller section ( as in the attached image ) and would like to use the Periodic BC on the shown faces ( Pb with Pa and Pb,rot with Pa,rot ).
NOTE: that Pb,rot is on the other side and cant be seen in the image.
I define them as interfaces and tick the periodic Boundary condition option with the automatic compute Offset on.
I am using the MRF method with the top part being stationary.
When i run the simulation, FLUENT shows the following error,
Error: Non-conformal periodic interface with empty intersection.
Primitive Error at Node 0: Couldn't intersect threads 11 and 12.
Primitive Error at Node 1: Couldn't intersect threads 11 and 12.
Primitive Error at Node 2: Couldn't intersect threads 11 and 12.
Primitive Error at Node 3: Couldn't intersect threads 11 and 12.
This is likely due to incorrect specification of periodic
offset values. Please check the offset values specified
and recreate the interface.
Error: Couldn't intersect threads 11 and 12.
Error Object: #f
Because of the blade curvature I dont know how to manually calculate the offset angle.
Please help.
Thanks a lot !!
rvl565 is offline   Reply With Quote
Old   August 7, 2013, 17:46
RacMat
I think i found the solution
http://www.cfd-online.com/Forums/flu...-tutorial.html
impeller, mrf, periodic boundary
Periodic boundary condition in 2 directions arash FLUENT 21 July 25, 2018 13:44
About periodic boundary condition. kohel_11 FLUENT 3 July 30, 2013 08:37
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Periodic Boundary Condition Swapnil CFX 1 December 17, 2002 22:59
