I need help about radiation (surface to surface- s2s model)
Old   August 5, 2013, 17:43
Exclamation I need help about radiation (surface to surface- s2s model)
miyage
miyage218 is on a distinguished road
hi everybody, I want to ask a problem about radiation. I will compute a problem which includes radiation heat transfer effect. but I want to calculate view factor, sometimes calculetes correctly sometimes wrong. have you any experience about this? how can I calculate true value of view factor everytime? which factors do depends view factor? I am waiting your replies.
miyage218 is offline   Reply With Quote
Old   August 5, 2013, 23:39
François Grégoire
macfly is on a distinguished road
Maybe you need to read some heat transfer book in order to understand the s2s model and the view factors. It's 100 times more efficient than asking on the forum. e.g. http://ca.wiley.com/WileyCDA/WileyTi...ilter=TEXTBOOK
macfly is offline   Reply With Quote
Old   October 1, 2014, 05:02
Al
donQi is on a distinguished road
See also :
chapter 13.3.7 of Fluent 6.3 Radiation Model Theory pag 995 (http://aerojet.engr.ucdavis.edu/flue...f-download.htm)
The surface-to-surface radiation model can be used to account for the radiation exchange
in an enclosure of gray-diffuse surfaces. The energy exchange between two surfaces de-
pends in part on their size, separation distance, and orientation. These parameters are
accounted for by a geometric function called a “view factor”.
[from Fundamentals of Heat and Mass Transfer Incropera chapter 13.1 pag812]
The view factor F_ij is defined as the function of the radiation leaving surface "i" that is intercepted by surface "j".
donQi is offline   Reply With Quote
Old   March 31, 2021, 01:00
Default s2s radiation model
noorlina
lieyna is on a distinguished road
Hi dear,
I tried to open the link but it cannot work. Could you please give the title of the book?
Thanks in advanced
Originally Posted by macfly View Post
lieyna is offline   Reply With Quote
radiation, s2s, s2s radiatiation model, viewfactor
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
S2S radiation model nenazarian FLUENT 1 January 17, 2013 03:36
Model with Thermal radiation Roland R CFX 4 June 15, 2012 07:59
heat transfer with s2s radiation model in fluent D. L. FLUENT 3 July 31, 2008 08:40
S2S radiation model Mo Mirsadeghi FLUENT 1 December 8, 2007 15:36
