FW-H acoustic permeable surface in Fluent
Old   July 31, 2013, 09:15
Default FW-H acoustic permeable surface in Fluent
levivad is on a distinguished road
I'm simulating an unsteady, low Mach number (M<0.1) flow. I also want to measure the generated sound.
I know that to find the sound caused by vortices I must enclose them by a "permeable surface" and define it as the sound source.
This also means that I must use compressible simulations with the ideal gas law.
The question remaining is whether I must reduce the time step to achieve a Currant number less then 1, even if the flow frequency is very small?
Since I'm capturing the boundary layer, this will cause a time step 3 orders of magnitude smaller then the flow time scale.
levivad is offline   Reply With Quote
Old   March 24, 2014, 15:20
HPUR is on a distinguished road
Hi! I'm trying to simulate jet noise in subsonic nozzles and I came across your post here.I would like to know how I can introduce an acoustic permeable surface in order to enclose the noise sources along my computational domain.I appreciate it if you could give me some guidance about it.
HPUR is offline   Reply With Quote
Old   April 7, 2014, 08:53
Jason
jasonbot is on a distinguished road
Create a new named selection in your geometry/mesh that encloses your model.
jasonbot is offline   Reply With Quote
compressibility, compressible flow, courant number, fluent 14
FLUENT Spreading diameter surface monitor query EIvb FLUENT 1 May 22, 2013 09:13
Surface tension force expression at the wall in fluent IndrajitW FLUENT 0 April 15, 2013 09:37
how to simulate drop impact on a solide surface using fluent wbka FLUENT 0 February 14, 2013 16:50
FLUENT 6.1.18 does have steady state acoustic mode Gavisiddayya FLUENT 0 October 8, 2007 12:24
making line surface in fluent rosol FLUENT 0 October 6, 2007 03:59
